Is it possible to create quick filters to see my sprint board by Assignee and other one to see it by Epic.
It will work as the Swirliness (Epics and assignee) except the bottoms will be visible on the board and I wouldn't have to press 3 configuration bottoms every time I want to switch to them.
Hello @Ana.Peskin and welcome to the Community!
If I'm understanding your inquiry correctly, you won't be able to change the view of your sprint board to group by epics or assignees using quick filters. Quick filters only show/hide data, they do not change the board layout or configuration.
You could create a separate board with the same configurations as your current one, where 1 board would have issues grouped by assignee and the other board grouped by Epic. Yes there would be 2 boards that you would have to switch between but this would be 1 click instead of 3.
Hope this helps
