REST API - How to get issue and request type initial workflow state?
Ian Carlos
September 13, 2023
Hi, I hope you're fine
I'm performing some calls to the Jira REST API using PHP
I would like to know how to get the first state of an issue type and a request type (yes, for both, since some of my projects don't have request type)
Is there a way to get this? How? Please help me out
I think that I could get the workflow and the info will be there, but I don't know how to get the workflow for issue and request type
Thanks in advance, best regards
Naveen Kumar_Appfire
September 13, 2023
HI @Ian Carlos
Calling the below rest API you can get all the information that is related to the issue in a JSON format.
https://test.atlassian.net/rest/api/3/issue/TEST-12
In JSON format you can get the IssueType and RequestType and Status of the issue.
Ian Carlos
September 13, 2023
Hi @Naveen Kumar_Appfire thank you for your fast reply
I've used this call before, is fine and works
The thing is, this is not what I want, and sorry if I missexplained myself
I want the workflow initial status of an issue type (not an Issue)
i.e.
    I want to know the initial state when an Incidence is created (before create it)
This for Issue and Request Type (Due that my Company - Managed Software projects don't have Request Types, only Issue Types)
Thanks in advance
And sorry if I missexplained myself
Register now
