REST API Use with cURL
Fariha Raza June 21, 2021
I'm new to APIs and how it is implemented in Jira. I've read the articles online, but I am having some issues accessing the localhost. How can I use the API with cURL to create an issue?
Hyrum Steffensen _Appfire_
June 21, 2021
Hello Fariha,
See this REST API documentation on creating an issue. Create a an API token here. I found it easies to use Postman to generate the authorization hash. Choose basic authorization and enter your Atlassian username and API token. See this on generating curl code in Postman.
A basic curl script looks something like:
curl --location --request POST 'https://<your prefix here>.atlassian.net/rest/api/2/issue' \
--header 'Content-Type: application/json' \
--header 'Authorization: Basic <auth hash goes here>' \
--data-raw '{
"fields": {
"summary": "summary goes here",
"issuetype": {
"id": "10002"
"project": {
"id": "10000"
Please let the Community know how it goes.
Hyrum
Fariha Raza June 22, 2021 edited
Thanks for the response! I have created a token. I'm running into the issue where the localhost is not being found when I put in that. For instance, when I press "Send" in Postman, it says "Could not get any response." Is this an issue with not having started Jira or something?
FREE
Register here ⬇️
