My use case :
For each release, I have to have a dashboard for that particular release. This dashboard contains data from multiple filters. With each release, the only changing variable would be the "Fix version".
Currently, I create new filters with the new fix version and then make a new dashboard to showcase that (editing past filters is not a solution since those dashboards should show data related to that particular fix version)
What I ideally need is just one dashboard. But at the top I should have a dropdown to select Fix version. Once I select it, all the filters in the dashboard get updated. In this way, I don't have to remake dashboards or filters.
Cannot be done without an external plugin. Can be done with this on JIRA Cloud : https://marketplace.atlassian.com/apps/1220136/quick-filters-for-jira-dashboards
Just to confirm your use case:
Without an addon I wonder if the following might work?
… fixVersion in unreleasedVersions()
obviously this would require that you only maintain a single unreleased version which would be your current release that you’re working on. If this is not an option then consider an add-on. I seem to recall there’s one that supports dynamic filtering.
Yes, and... to what Jack suggested is to use earliestUnreleasedVersion() in your dashboard filters.
Best regards,
