Rearrange fields on view issue screen gloabally for all projects
Avinash Kagita
June 21, 2023
How can we rearrange fields on view issue screen gloabally for all projects that share the same screen schema?
I tried to moving the fileds to the top of the screen, but those changes are not reflecting in in view screen for the projects.
I see that if we go to the individual project and change the issue layout, then only the changes are reflecting for that specific project. How can we do this all projects that share same screen schema?
Trudy Claspill
Hello @Avinash Kagita
You can use the Copy Layout option to copy layouts between projects where the same screen is used. Refer to:
https://support.atlassian.com/jira-software-cloud/docs/copy-an-issue-layout-to-other-projects/
Avinash Kagita
June 26, 2023
Thank you @Trudy Claspill
