I have a multiline custom text field which I would like have a default value, but validate during one transition that the value is still not the default value. I have a strong preference to not use Jira Automation, but the Workflow editor (but it's definitely a fallback option!)
I have put in a multiline default value (this is an example, my actual one is 9 lines):
Line 1:
Line 2:
Line 3:
I have a required field validator (which works fine), and I have added a Regex validator:
^(?!Line\s1:\s\nLine\s2:\s\nLine\s3:\s)[\s\S]*$
So this does a negative lookahead for the specific value and fails if it find it exactly (even if there's other stuff directly after). But, it passes if there's even one character difference, which is what I want.
So here's what's weird that I don't understand and need help with:
Is there something special about default values that it doesn't register as either empty, or the actual default value text? I don't understand why it seems to accept the text value if I paste over the default value with itself.
Register now
