Remaining time is not calculating correctly
Susanne Moore April 23, 2020
There are a couple issues with Time reporting on JIRA that are becoming very irritating and for what this community pays in subscriptions; there is no reason this should not be resolved. Known Issues that need to be corrected:
  1. When using the Dashboard with Epics and Tasks the time remaining is calculated correctly, however, when using the Dashboard with Epics and Stories and Tasks the Dashboard report incorrectly under these circumstances:
    • Because the Epic seems to reports time wrong when a person logs time at the story level and there are subtasks.
    • The Story reports remaining time wrong when any one of the subtasks exceeds its estimates.
The desired behavior would be that subtask estimates roll up to the story (which is does today). When one logs time it calculates the remaining time correctly at the subtask level and that rolls up to the story and the stories roll up to the Epic. Then when one records their time on the subtask and that time exceeds the estimate, the time remaining goes to 0. It would also be good if in the story, time remaining was displayed next to each task so you did not have to go into the subtask to see the time remaining.
Scroll right on the image to see the area of concern.
