Reminder to log work
Lusca Fontoura
June 10, 2021 edited
Hey!
I'm trying to set up a rule to notify the assigne that he/she forgot to log work that day.
My idea is to check about 5PM if the assignee logged work, if not, notify the person via email.
I tried with this JQL, but it's not working, it's still getting the other tasks whithin:
project = XXX AND issuetype in (História, Task) AND status in ("XXX", "XXX", "XXX", XXX) AND worklogDate >= -1d
Any ideas?
Adam Rypel _MoroSystems_
June 11, 2021 edited
Hello @Lusca Fontoura ,
So if I understand correctly, you are trying to find the issues, which were not logged today, is that right? You could use:
project = XXX AND issuetype in (História, Task) AND status in ("XXX", "XXX", "XXX", XXX) AND worklogDate < startOfDay() AND assignee = currentUser()
Lusca Fontoura
Yeah, that's what I'm trying.
I did what you suggested, but still not working. I begin to think that there's a bug.
When I try that JQL you suggested, it shows all the issues in the project.
I logged work on one of them, to see if something would change and the JQL still got me the same result.
I changed the JQL to "AND NOT" before workLogDate, to check if it gets just the one I logged work and this one worked well. So why the suggestion you gave me isn't work?
Isn't this a bug?
That is interesting, I am trying this with different scenarios but everything works well for me with worklogDate < startOfDay():
  • I tried to log the work to the past and log the work for today and the result is correct - only issues in the past are shown.
  • If I try worklogDate >= startOfDay(), only issues logged today are shown.
  • If I put NOT before worklogDate < startOfDay(), issues with log from today are shown, which is correct (works same for the other way around).
  • I tried that with combination of other fields, as project and status and everything works fine as well.
The only thing I noticed is, that Jira ignores the time you enter during the log work - all the worklogs are always set to 00:00. So if you log now for today, the date and time would be "11/06/2021 00:00".
I cannot really tell for sure if this is a bug or not. I have just found this reported bug, which relates to NOT though: https://jira.atlassian.com/browse/JRACLOUD-74621 , which also does not seem to appear for me though.
Since you are on a Standard plan, I would suggest to raise a support ticket with Atlassian - that will probably be quicker and they can help you with that more.
Also it would be nice to share the results of the solution with Atlassian here.
Adam
Like • Lusca Fontoura likes this
Lusca Fontoura
So, what I was trying to do was the scenario 3, like this:
  • project =XXX AND issuetype in (História, Task) AND status in ("X", "X", X) AND NOT worklogDate > startOfDay()
With this one I get the only issue I logged work today.
After that, I did some changes, and got the same result:
  • project =XXX AND issuetype in (História, Task) AND status in ("X", "X", X) AND NOT worklogDate < startOfDay()
Looks like with > or < I get the same results, showing just the one I logged and not showing all the others. :(
Lusca Fontoura
Actually I found a solution:
1. I made the filter I said before, with the tasks and stories that got work logged.
2. I made a second filter searching for all the tasks and stories in the project that are not in the previously filter.
Now I can keep working, hehe. :)
Like • 2 people like this
Sorry, I see I linked wrong ticket before, should be this one, where this solution is mentioned: https://jira.atlassian.com/browse/JRACLOUD-74624
Glad you got that working! I would keep checking the results of filter for couple of days, to see if everything is working fine, since it seems the behaviour of worklogDate is a bit weird.
