Rename "Issue" word in Jira Cloud
WAJDI ALZINATI July 22, 2020
How can i rename "Issue" word in Jira Cloud? also is there any solution to sync issues between Jira Server & Cloud to be as an active link?
Rik de Valk
Hi all,
There is finally an update on this topic!
Atlassian is renaming the Issue.
You can read more about it here: https://community.atlassian.com/t5/Jira-articles/Choose-how-you-want-to-represent-your-work-in-Jira/ba-p/2812617#M15681
Have a nice day!
Rik
Michael Carter
November 30, 2022
I have a real issue with the word, "issue" being baked-in to Jira. Aside from the emotional tone of the word, it's just not apt for proactive tasks. Sure, if there's a bug / problem / ticket, there's an "issue" to resolve... but when you are using Jira for managing the creation / building of things, "issue" just doesn't fit. Atlassian should provide a global variable where the word can be edited to be what works for the organisation -- e.g. Task, Item etc.
George Haney November 30, 2022
I totally Agree that this has been asked for since 2012 is a total showing that they either don't know how to decouple it or they looked into it and it costs too much...
The questions is :  What are we going to do to get them to listen? It isn't like we are converting to Click Up or Monday,com in sufficient numbers to make the notice.
George Haney August 5, 2022
Vote for this on Atlassian
Change title "Issues".
https://jira.atlassian.com/browse/JSWCLOUD-21475
Matt Wilkie
Voted. tried to leave a comment to but the form wouldn't let me save.
"Yes please! 'Tasks' is a much better term for our team than 'issues'. The prevalence of the term everywhere in the interface and reports is frequently brought up by our manager as a reason to search for another platform besides Jira."
Like Michael Carter likes this
Mike Rathwell
July 22, 2020
Hi @WAJDI ALZINATI ,
So... for your two questions:
  • The short answer to renaming "issue" is... nope. I think this stems from Jira's genesis as a bug tracking tool and hasn't updated to match it's new world ability as a very capable process engine. In my shop, nobody refers to a Jira "issue"; everyone just calls them "tickets"
  • For syncing issues, the best thing you could do is start with federating your on prem and cloud instances. This page provides a good primer on that. I am not doing this now but have done so in past shops and federated Jira instances work well. Another bonus is that, if you connect all your instances to a Confluence instance, it also can see and use all of your federated instances.
Jack Brickey
actually I like "issues" for JSW. i use "tickets" for JSD. but that is just me. :-)
Matthias Gaiser _K15t_
The official term for JSD would actually be requests.. at least according to the REST API naming :)
To add on what @Mike Rathwell said, his page recommendation is a good read.
To sum it up, you have to choose between these options:
  • Linking
    • You want to create application links between the different Jiras/Confluences so they know each other and you can create links between them.
  • Syncing
    • You choose an app for issue syncing which actually updates the tickets bidirectionally.
    • You can choose to implement the syncing yourself using some automation or scripting tool.
You have to choose what matches best your needs. If you're not sure, you can also try to describe your needs in more words to get better recommendations from the Community.
PS: I'm part of the team behind Backbone Issue Sync, so I might be a bit biased.
FREE
