Report with worklog and description in report/list
Marcel Vlems August 25, 2022
Is it possible to show the worklog of one or more issues in a report/list which I can export to Excel?
I also found some apps that can do the job but I was wondering if it was available in the standard version of Jira.
Rahul_RVS
Hi
@Marcel Vlems
If you are fine with a mktplace app, to get this data, you can try out our plugin
Agile Tools : Epic Tree, Links Tree, Time in Status & Worklogs
The app provides the following features.
Worklogs & Time tracking Report :- Track time spent by resources with multiple filters / category / grouping features. Export to csv format is also available. You can filter based on worklogs time period as well.
Trudy Claspill
Hello @Marcel Vlems
There is not a built in report for that. You will need to look for third party apps, or consider using the REST API to extract the worklog data.
If third party apps are an option, this article might help you.
https://community.atlassian.com/t5/Marketplace-Apps-Integrations/How-to-generate-user-worklog-reports-in-Jira/ba-p/1677530
Register now
