I am creating a new Next Gen project and attempting to set a Checkbox to be required but am not successful. These are the steps I followed:
1. Created New Project
2. Selected Project Settings - > Issue Types --> Add Issue Type
3. Created Issue Type
4. Added the Check Box to Context Fields
I can now create a ticket with the issue type but the Check Box is not set to required and I do not see the option. I am also trying to do this without creating a custom field or without creating a screen. Can anyone assist? Thanks.
Hi @Craig Lashley,
Next-gen projects do not have the option to make fields required. If you want to control if a field is required or not you would need to use a classic project instead.
Thank you. When using the Classic version will I need to use custom fields and screens to make a field required on a custom field type?
You can either use a field configuration to always make the field required, or you can make the field required when the user is doing a specific transition.
