I am looking for a Requirements Management app that works with Next-gen projects in JIRA Cloud or Confluence Cloud.
All the options so far seem to either work only for the self-hosted Atlassian products or do not support Next-gen projects in JIRA Cloud. The one third-party app that seems suitable has very poor reviews.
Would appreciate some inputs/suggestions.
Sandip
Hi @sandip ,
welcome to the Atlassian Community!
I believe the reason you're not able to find anything is the next-gen projects were not designed for such purposes.
I think it would also help, if you define, which functionalities you expect you have available, how does you process looks like etc.
Maybe you don't need any specific functionality, maybe some classic project with specific workflow would be enough...
