For a particular Status, I want to see particular resolutions. For example, when I select Status as Invalid I want to see the Resolutions like: Duplicate, Not a Bug, Issue doesn't exist etc. in the resolution dropdown screen. Again when I Select Status as Fixed I want to see Resolved, Tested and Fixed in the resolution dropdown. Is this possible?
Hi @Anik
you can restrict the resolution option by using workflow properties,
add the following propety on transition properties as key values
jira.field.resolution.include =1,2,3
1,2,3 is the id's of the resolutions
Regards
Dave
