Resolution field missing from post-function
Season Hughes
I am trying to set up a post-function in my workflow to clear the Resolution field when Issues are moved from Closed to To Do.
When I try to set up the post-function, the Resolution field doesn't show up in the drop-down.
Any ideas how I can get Resolution to populate in the dropdown?
Melo
Hi @Season Hughes,
Try using the "Update Issue Field" post function. It should give you the right option.
postfunc.PNG Cheers,
Melo
Season Hughes
You're a lifesaver, Melo - thank you.
Like • 2 people like this
