Rest API call to extract Status Transition dates
nikita
I've been using the changeLog expanded rest api call to our jira instance.
During the fields investigation, I discovered on one issue the transitions expanded has 13 recorded status transitions. These are recorded under the expand=transitions field.
However, there is no record of these status transitions in the expand=changelog histories.
Can someone explain why this is?
And if the task did actually transition through these 13 status changes, how would I find the date and time and user who made these transitions?
nikita
It seems the transitions field expanded is like a lookup table, and these are all the available transitions for the issue in question. If I am incorrect please let me know, this is what it seems to be though.
Zoryana Bohutska _SaaSJet_
December 14, 2020 edited
Hi @nikita
As an alternative, you can try Issue History app. It lets you view all types of issue changes, including status transitions. You need to select 3 issue fields in the app`s column manager: issue key, summary, and statuses.
As a result, you will get the full report of status transitions for each issue. Also, this add-on shows when and by whom those changes were made.
I hope it will help
Help us plant more trees
