Restrict tab on create issue screen
Gnanabaskar
How to hide or remove a tab on create issue screen . I want to see the fields on a single screen itself.   There are 2 tabs or pages, which is not required. Please suggest a solution.
Thanks.
3 votes
Ste Wright
Hi @Gnanabaskar
If there's a tab, it's because the screen has one configured.
You'll usually need to be a Product/Org Admin to fix this. Then I would...
  1. Go to your Project, into Project Settings
  2. Select Screens from the left-hand menu
  3. Open the relevant Screen Scheme for this Issue Type, and choose the Screen
  4. Go to the tab, and move the Fields into the main field tab - then remove it
  5. Repeat steps 3-4 if there are multiple screens for different Issue Types / Screen Operations
^ This will remove the tab format. If a screen only has one tab (the field tab), it acts as if there isn't one.
Ste
Gnanabaskar
Thanks @Ste Wright
Answered my question.
Like Ste Wright likes this
