Reuse custom field in another project
Monika Katipally January 18, 2017
Am trying to use a custom field that is already in use for one project, to be available and usable in another project.
I added to the field in the new project Issue Screen Scheme by which it shows up on the Create Screen.
But the values are not showing.
I would appreciate any insight on the steps to achieve this
Nic Brough -Adaptavist-
January 18, 2017
Check that the field configuration does not hide it in the new project, and that the field has the right "context" - you'll need to check that in the list of custom fields (it may say "only valid in projects A, B and C" for example)
Also, as an admin, try the "where's my field" option
Register today
