I'd like to make the roadmap visual available publicly (not requiring a jira user login) -- ideally this data and/or view is available in the Jira API. Anyone have luck with this?
Hi @Mac McCabe
I'm not sure the visual is available via the API - but all the data is just issue data that can be accessed and re-visualised in a similar format elsewhere (for example, in a BI tool).
I would consider checking out the REST API documentation, to help with this process.
Ste
Here's the problem. I'm not seeing the "start date" nor "due date" in the available data.
Hi @Mac McCabe
You should be able to locate the correct field parameters from viewing an Epic's issue details.
You could use:
This should help you identify what information to pull :)
Ste
Hey everyone! Are you ready to make a difference? Join the Atlassian Social Impact Bingo event! ❌⭕
Play Bingo! 🙋🏻♂️Online forums and learning are now in one easy-to-use experience.
