I recently migrated a project using cloud to cloud migration assistant. Following is the error displayed on road maps
"A JQL filter is blocking your roadmap
Hi @Suyash Rane ,
To fix the error, just update your filter to the following:
project = PRISAAS AND type in (Epic, Bug) ORDER BY Rank ASC
I can imagine you will still need to figure out how you want to relate bugs to epics to then build a sensible roadmap afterwards, but I expect this should eliminate the error.
Hope this helps!
Thanks a lot, that helped!
Since there were too many issues, we had to add some conditions around resolution as well.
