The option of verify domain can directly import users associated with the domain without using any tools like access or any third-party SSO? , let suppose I have mails associated with the domain, So I can import all user associated with the domain without any AD integration just by verifying domain
Hi @Syed Muhammad Ammad Mansoor,
Verifying your domain just does 2 things:
It gives you / your organisation the following benefits:
More control over the Atlassian accounts on your company’s domain – those accounts become managed accounts, which means you can edit, delete, or deactivate their accounts.
The ability to apply security policies to your managed accounts – you may want to require log in with two-step verification or set up SAML single sign-on so that policies from your identity provider apply to all Atlassian accounts. You can do both by subscribing to Atlassian Access.
That last bit is important. Applying security policies and setting up an AD-integration and SSO does require Atlassian Access. It does not happen just by verifying the domain.
For a detailed description, check out this support article.
Hope this helps!
