×Good Afternoon
Does anyone know if there is any way of rolling up the estimates of issues under an epic within the Advanced road map feature?
I am looking for something which works similarly to the Dates roll up feature in advanced road maps, but totaling the estimated days rather than rolling up the dates of the timeline.
Any help would be greatly appreciated. I am not sure if you can do a running total outside of roadmaps either, but this seemed like the easiest place that it would be possible.
Cheers
Steven
Hi Steven,
This is definitely possible. Just head to your View Settings panel, and check 'others' in the roll-up section:
This will populate the roll-up of days in your estimate field.
Hope this helps!
Emma
