Could you please send me an example of a rule to set an Insight field after issue creation?
I have a text field containing a name of an employee
User
Also I have an Insight custom field
Employee
When I create an issue I want Jira to find an object in Employees table which name equals to User value. In terms of IQL it looks like
"Name" = {User.value}
This does not really work
If you want to find the object for the reporter's user then you can use the IQL in "Lookup Object" step as follows:
Name = {{reporter.DisplayName}}
I hope that will help.
Hakan Bahadir
Solutions Engineer
Thanks Hakan.
Is it possible to create Insight object from rules?
Also is it possible to edit attributes of an object?
Yes, absolutely. Please find the automation blocks newly introduced for Insight below:
- Triggers: Object trigger,
- Conditions: IQL Condition
- Actions: Lookup objects, Edit Insight field attributes (works for the issue in context), Edit object (works with Object trigger)
Cheers.
Hakan Bahadir
Solution Engineer
Are these Insight actions only for Cloud based Jira instances? I don't see a lookup action in my Data Center instance.
