Screen Tabs Restriction
VJ
September 15, 2021 edited
Good day!
Is it possible to restrict tabs in screen for specific user group or role?
When the BPMD Usergroup clicked the issue, they can only see the Form and BPMD tab?
I saw a similar question here but I don't have a scriptrunner. I was wondering if there's another way.
Thank you!
Alex Koxaras _Relational_
Hi @VJ
Unfortunately is not currently possible to achieve this with out of the box Jira functionalities. It simply doesn't support this. Script runner (I supposed you've seen this solution) is most likely the way to go. Tbh I didn't search in the marketplace to see if any free app might do that work for you.
VJ
Hi @Alex Koxaras _Relational_
Yes I saw it, appreciate the feedback. I will definitely try the scriptrunner instead.
Like • Alex Koxaras _Relational_ likes this
Kindly mark this answer as accepted, in order to help others in this community to find the right answers. Thanx!
Like • VJ likes this
