Script Runner Behaviours not running
Alistair Attrill
I have enable the basic behaviours in the project and against some types.  But they are not activating.  It must be something obvious but i have read and googled and cant find out why its not working.  These are just the basic examples?
Any Help please?
Duc Anh Le
Hi @Alistair Attrill - I am running into the same issue. Any chance you had a solution for it? Thanks
Alex Koxaras _Relational_
What is it that you are after? I mean what do you want to do to the summary field?
Alistair Attrill
https://docs.adaptavist.com/sr4jc/latest/features/behaviours/example-behaviour
Running this example to test if it works and it doesnt, as i couldnt get a more complex one to work i tried this.
I've tested this script and works fine:
Did you tried to create a ticket on THAT specific projects, while choosing the TASK or HARDWARE issue type which you have defined on your behaviour?
Alistair Attrill
Yep, it doesn't make sense.  Im on cloud, not sure if thats difference, or something about the type of project or if its not installed correctly...
@Alistair Attrill it seems you are working on Jira Work Management. I have a feeling that Behaviors are not applicable for Jira Work Management:
@Alistair Attrill hi!
Are you working indeed on Jira Work Management?
