Script Runner Validator to check if the issue is linked with a Specific link type.
Ganesh Kumar Vary March 26, 2023
Hi all,
I have a requirement where a User Story should be moved to next transition only if it is linked to another User Story with link type Addresses.
I have used a simple one-line Script: issue.links.length >0 in the Script runner Validator which is restricting the transition when there is no linked issue. But I couldn't find a way to include the link type in the validator. please see the SS attached for more detail.
Can anyone suggest me a syntax so that I can include the link type also here?
2 accepted
5 votes
Alex Koxaras -Relational-
Hi @Ganesh Kumar Vary
I would use something like:
issue.links
.map(it =>it.type.name == "Addresses")
.filter(i => i == true)
.length > 0
Keep in mind that "Addresses" should the name of the link type, not the names of the inward/outward links .
Ganesh Kumar Vary March 27, 2023
Thank you @Alex Koxaras -Relational-  this solved my problem. I Appreciate the quick response.
@Ganesh Kumar Vary kindly mark both answers as accepted then, to help others in the community with similar problems. Thank you!
Juan Carlos Vera
March 27, 2023 edited
Hi @Ganesh Kumar Vary ,
You can try this ScriptRunner Validation:
issue.links != null ? issue.links.some(link => link.type.name == "Addresses") : true
Thank you @Juan Carlos Vera  this solved my problem. Bothe solutions worked fine for me. I Appreciate the quick response.
Ganesh Kumar Vary May 9, 2023
Can I check if the linked issue is a Specific issue Type here?
something like the linked issue type should be either Epic or Story issue type.
Learn more
