Scriptrunner how to mention reporter in comment using Postfunction script
Wajdan May 22, 2022
Hi would like to know how to mention reporter in the comment in the post function custom script in workflow transition
Andy Rusnak
May 23, 2022
Hi Wajdan,
Thanks for the posting to the Atlassian Community!
If I understand properly what you are attempting to accomplish here, I believe the script I have written below may be able to serve as an example for you. You may need to modify this for your needs, but this may be able to help you get started:
// Get the Reporter of the Issue
final reporter = issue.reporterUser;
// Set the user that will post the comment to the issue (in this case
// it is the user that transitioned the issue)
def transitionUser = ComponentAccessor.jiraAuthenticationContext.loggedInUser;
// Create your comment text and reference the reporter user.
final String commentText = """This is a comment [~${reporter.getName()}]""";
// Finally post the comment to Issue
ComponentAccessor.commentManager.create(issue, transitionUser, commentText, true);
Others on the Community may have other ways to accomplish this as well, this was just a quick example I put together and validated that it works for a simple case.
If you have any questions related to this or if I have misunderstood your request please let me know and I would be happy to chat further.
Best,
Andy
FREE
