×It is possible to use scriptrunner as an excelsheet?
There is a field "a" and a field b. Can I show in the field "c" the result of:
c = a + b
¿Is it possible to do in real time?
Thank you very much!
Yep, you might want a quick look at https://community.atlassian.com/t5/Jira-questions/to-automatically-replenish-Duedate-by-Severity-when-creating-an/qaq-p/1990926 - it's got more complex (date) calculations in it as an example, you should be able to simplify it down quite easily.
Thank you for your answer, Nic.
However, we are using Jira Cloud, and the suggested solution imports three classes (com.atlassian.jira.component.ComponentAccessor, com.atlassian.jira.issue.MutableIssue, com.atlassian.jira.event.type.EventDispatchOption) which aren't available for Jira Cloud (we get messages like "unable to resolve class com.atlassian.jira.issue.MutableIssue").
Is it possible to show the calculated results in real time on Jira Cloud?
Thank you!
Scripts for server don't work on Cloud, you have to do it very differently.
I should have given you this instead: https://library.adaptavist.com/search?platforms=cloud
