Hi everyone,
We found that two fields are called roughly the same thing: `Story points` and `Story Points` in the Jira settings.
This causes an issue elsewhere on our system and would love to get this fixed.
This is *not* about `Story point estimate` which is also another field we have but do not causes any issues.
Upon going to Jira / Settings / Issues / Fields, I do see the following Story points fields:
That being said, I cannot find the `Story points` field any where in the custom fields list. Only `Story Points`:
Could you please let me know if I'm missing something obvious?
Hi Nick,
Thanks for the suggestion!
It was indeed a team-managed project but really hard to find.
For future reference, what I ended up doing was to use the API:
- List all custom fields (It did list the two custom fields)
- the culprit custom field had a scope indicating the project ID.
- Listed all projects and found the project itself.
- Trying to delete via the API but receive a 404 error when using the ID returned by the API. I'm still unable to find the field in the UI to delete it.
Would you know why a 404 is returned here?
The actual error:
"errorMessages": [
"Field not found."
"errors": {}
We found a way to delete it from the UI (Next Gen project are quite different)
The "system" story points field is not locked like the "story point estimate" because it does not need protecting against mis-configuration, bu it is the easiest (and hence best) one to stick with.
You are not missing anything obvious, it's just that someone has added "Story points" somewhere, when they should have just re-used "Story Points" to be consistent.
I suspect it has been added to a team-managed project, so it's going to be a bit of a pain to find, but try running a search for "Story points is not empty" (with the capitalisation you've got in your field list), this should at least tell you which project has it.
