Send an email notification via automation to recipients on a multi picker user field.
Tiago Pereira
I am trying to send an email to each user mentioned on the multi picker user field.
I tried {{issue. TI Approvers}}, but I get an error saying no users are available, but there are 2 actually.
This smart values works for single user field, but it seems not to be working for this case, can you help
Tansu Akdeniz
September 19, 2023
Hi @Tiago Pereira
Please be careful if there is extra space etc.
Also check the answer in this thread: Automation to email users in a custom field
Tiago Pereira
Tried w/ field ID still the same issue, error saying field is empty when is not
Marc - Devoteam
September 19, 2023
Hi @Tiago Pereira
What project type are you using Team or Company Managed?
If you're working with a Team Managed project.
Automation for Jira does not yet support the People field used in Team Managed projects, unfortunately. Listed in multiple change requests in the Atlassian backlog:
https://jira.atlassian.com/browse/JSWCLOUD-22200
https://codebarrel.atlassian.net/browse/AUT-2248
The problem is also mentioned in several community posts. Here is one that mentions a workaround using the Send Web Request action to get the email addresses
https://community.atlassian.com/t5/Jira-questions/Automation-send-email-to-all-users-listed-in-custom-People-field/qaq-p/1807325
Tiago Pereira
Tried w/ field ID still the same issue, error saying field is empty when is notScreenshot 2023-09-19 124441.pngScreenshot 2023-09-19 124501.pngScreenshot 2023-09-19 124519.png
Tiago Pereira
Tried w/ field id still the same issue, it says field is empty when is not
Tiago Pereira
Hauke Bruno Wollentin
September 19, 2023
I guess - but didn't tested that - that the field contains a list. Handling lists is described here, so maybe this helps out :)
https://support.atlassian.com/cloud-automation/docs/jira-smart-values-lists/
Tom Lister
September 19, 2023
is the space in {{issue. TI Approvers}} intentional?
Like Hauke Bruno Wollentin likes this
Tiago Pereira
Yes the space is intentional
Tiago Pereira
also tried w/ field id & is the same issue
