Sending attachment through web request (automation)
atarab
Hi all,
We have an automation rule that sends certain comments via web request to a 3rd party app we use.
It works great, except with attachments. When trying to send an attachment all that is sent is the file name.
Is there a way to send the actual file through a web request?
Thank you
Pramodh M
@atarab
It's not possible!!
Attachments Automation is still a feature request
https://jira.atlassian.com/browse/JSDCLOUD-3371
Here's the alternative & reference
https://community.atlassian.com/t5/Jira-questions/Automation-Send-an-email-with-the-attachments-attached/qaq-p/1532428
Pramodh
Boris Berenberg - Atlas Authority
February 7, 2022
Pramodh is absolutely right. This is still not possible, and we are still supporting it in Notification Assistant for Jira ðŸ˜„
Like • Pramodh M likes this
Pramodh M
azadeh.nazari February 2, 2024
I need guidance.
I want to send a ticket to my customer from inside the ticket portal, and I attached a file to the ticket.
I created an automation. When a ticket is created, it should send an email to a custom field which is my customer's email, and the email is sent to my customer.
My problem is :  The email sent to my customer from the automation does not contain the attached file.
don't want the customer to log into the service desk via a link and see the file; I want the attached file sent to their email.
My problem is : And also, I want the customer to be able to attach a file to their email reply received through the automation, and I want to see the customer's response with the attached file inside the ticket comments
Does Jira Service Desk have this capability in automation?
Boris Berenberg - Modus Create
February 2, 2024
It does if you use Notification Assistant for Jira. Otherwise, no it does not.
@Boris Berenberg - Modus Create
Thank you for your help,
If I set the notification to send the attachment to my customer's email:
  • Can the customer respond to the notification from his/her email ?
  •  Can I see the customer's response on the ticket comments?
February 5, 2024
Yes to both questions.
