Sending email notification if workflow transition does not exist
Benjamin Lee
What we currently want to do is automatically update a tickets status to "UNDER REVIEW" based on a dev creating a pull request on GitHub. We currently have a single transition which changes the status of "IN PROGRESS" to "UNDER REVIEW".
I currently have a Workflow trigger that properly handles the change based on a trigger.
However, it is possible that a dev has forgotten to change their ticket to being "IN PROGRESS". For example, it could still be "OPEN".
In this case, there will be no transition, as OPEN -> UNDER REVIEW is not allowed.
In this case, I would like to send an email notification to the developer indicating the issue.
Is there a way I can send an email notification based on this situation? One work around would be to create a transition for OPEN -> UNDER REVIEW, but I would rather not do this. It is preferred to help provide the reminders to the devs on the correct flow they should be using.
John Funk
Hi Benjamin,
Maybe you could add an If / Else block to check the status after the trigger fires? If In Progress, then transition the ticket, else send the email.
Benjamin Lee
@John Funk thanks for the reply. This is Jira Cloud. Not sure if this matters. I have not seen a place I can do a if/else block. Nor how to send email in the trigger or after the trigger
It also dawns on me that I'm essentially trying to identify a "trigger" for a transition that does not exist.  So it would seem that I probably need some form of error handler to capture this case.
I'm not sure if this means I need a webhook or something to do this.
John Funk
I also use Cloud.  :-)
Start by reviewing here:
There are two types of automation:
  • Global: In the Free version, you get 100 executions per product, per month
  • Project: In all versions, you get unlimited executions per month
Automation Basics: https://www.atlassian.com/software/jira/guides/expand-jira/automation
You can do this via global rules to apply to all projects also. You'll need to be a Jira Admin/Site Admin, go to Jira Settings > System > Automation Rules (left-hand menu).
For more on using Automation For Jira see these help pages.
Benjamin Lee
Thanks John, let me read the documentation and see if I can figure something out.
Like • John Funk likes this
Benjamin Lee
@John Funk you are awesome my friend. This did it. I need to still learn a bit more on how to control it, but passed my initial tests.
I now have to convince folks to get the plugin. We are using DataCenter. But I was testing on Jira Cloud.
Just curious, in case I get shot down ... any viable alternatives that come out of the box in DataCenter?
John Funk
Haha - you are too kind, sir.  :-)
There is a Lite version app of Automation for Jira that is Free. You can compare the free vs paid versions (Lite vs Pro) here:
https://confluence.atlassian.com/automation/getting-the-right-version-993924597.html
