Sequence of automation fail to work
Alon Shoham
Hello!
I got 2 automations which I'd like to perform one based on the other.
The First automation creates an issue in a certain board. (e.g. Board X).
The second automation needs to change the 'status'. It should be performed in Board X, and it's based on 'Issue created'.
The sequence is:
1. Automation (#1) creates an issue in Board X (Works fine)
2. Automation (#2) needs to chage the status (transition) on a created issue (FAIL to work).
Automation #2 does not recognize the issue created by automation #1 as a trigger of 'created issue'.
Any suggestions on how to solve it?
3 votes
robert Mugabuhamye
August 25, 2022
hello @Alon Shoham ,
In the "rule details" section of automation #2 you should try to select this option :
Alon Shoham
So simple yet so genius !
Tanks @robert Mugabuhamye
robert Mugabuhamye
August 25, 2022
my pleasure :)
Learn more
