Could anyone please help me with the code of setting cascading drop-down custom field value as well as single list dropdown using ScriptRunner in Jira workflow post functions.
For the cascading select list please check the Adaptavist script library https://library.adaptavist.com/entity/set-a-default-option-on-a-cascading-select-list
Hi Rajaravikiran,
For the single list drop down you can use the following script.
{code}
// set a desired value in a single select list field
import com.atlassian.jira.issue.CustomFieldManager
CustomFieldManager customFieldManager = ComponentAccessor.getCustomFieldManager()
def cf = customFieldManager.getCustomFieldObject("customfield_xxxxx") // replace xxxxx with your customfield id
def optionsManager = ComponentAccessor.getOptionsManager()
def fieldConfig = cf.getRelevantConfig(issue)
def option = optionsManager.getOptions(fieldConfig).find {it.value == "xxxxx"} // replace xxxxx with the value you want to set in the field
issue.setCustomFieldValue(cf, option)
{code}
