Set DueDate based on FixVersion
Tanya Fraser May 9, 2023
I have an automation designed to set the due date automatically based on FixVersion but I can't get it working for me.
The automation says:
When the Value changes for Fix Version
Edit issue fields Due date, {{issue.fixversion.releaseDate.format("d/MMM/yy")}}
The automation says that it is successful and the Associated items field value says it is changed.
But when I go to the issue, the due date field is empty
The date field I have (d/MMM/yy) is the date field in the system. Is it possible my Release date format and my due date format are different?
Any help gratefully accepted!
Alex Koxaras _Relational_
Hi @Tanya Fraser
Try {{issue.fixVersions.releaseDate.format("yyyy-MM-dd")}}
Tanya Fraser May 10, 2023
Perfect, thank you!
Works now
I tried using jiraDate.
Also says that the automation is successful, but there is nothing displayed in the DueDate Field.
Tried using a custom field "End Date"
Same result - the automation says that it is successful but the field has no date.
By the way, the Releases have release Dates populated
Place a log component on the value you try to place on the End Date.
