I haven't found anything similar to my use case so hopefully my question is clear!
I have installed a third party add-on called QAlity Plus to create and link tests to Jira tasks. What I would like to do is create an automation based on the following:
Important information:
I'm sure this could be achieved through simple automation, but when I look at my audit logs the trigger issue is the created Test. Which isn't an issue until I try to get the Epic Link of the "tests" which I can't figure out how to get.
I've added a ss of my audit log because I've been continuously tweaking my trigger conditions and I'm getting the same result. Any ideas on how I can achieve the above? Thank you!
Hi @Kelly McAteer - Your rule would look something like this:
How this works... In the Issue Linked trigger, you get the following information:
Rule executes when an issue is linked to another issue. {{issue}} will always refer to the source issue, so if ISSUE-A is blocked by ISSUE-B, this rule will execute on ISSUE-B. To access ISSUE-A, use {{destinationIssue}}, and to access the link type, use {{linkType}} (e.g. {{linkType}}
In your case, you would substitute blocked by for is tested by where your Task would take the role of {{destinationIssue}} and your Test would take the role of {{issue}}. So, as you pointed out, the rule executes against the Test, so you just need to make a call on the {{destinationIssue}} to pull information from the Test.
This worked for me thank you!
This is the JSON I got working in the end to update the Epic Link for anyone who is wondering
"fields": {
"Epic Link": "{{destinationIssue.Epic Link}}"
@Kelly McAteer @Mark Segall I am struggling with this problem as well - when I tried the above JSON, I am getting an error on using "fields". Any clues? Only difference in scenario is I am using Xray testing, but still has auto linking when test issue is created through tests/is tested by.
