×Is it possible to set a default priority level for a specific issue type?
I.e. If IssueTypeA is created pre-select Priority Medium, If IssueTypeB is created pre-select Priority Low
You could set a "post function" in the user workflow on creation. If you select " Update Issue Field " and select priority to set to your wish this is possible.
I don't think it's a JIRA default option to set a default priority per issue type.
