HI,
I have created ticket type called 'important dates'.
I have set a 'due date' field that shows me when SSL certificate is about to expire or a contract is due for renewal for instance.
I have also created a calendar that contains all of these ticket types.
All these above are useful, but I am wondering whether I can set an email reminders lets say 1 month earlier date than the 'due date' that would trigger an email reminder to participants and assignee in that ticket.
Has anyone tried something similar please?
Many Thanks
Hi @Tomasz Bis
This is totally possible with automation. I would recommend a daily schedule with some type of flag that can be set so that users are not reminded daily. For simplicity my example will leverage a label called (notified), but you could easily use a component or custom field as well.
"Due Date" < 30d AND (labels NOT IN (notified) OR labels IS EMPTY)
{{issue}} coming up for renewal in 30 days
<a href="https://YOURINSTANCE.atlassian.net/browse/{{issue.key}}">{{issue.key}}</a> - {{issue.summary}} is coming up for renewal.
Thank you @Mark Segall for the above.
I am not sure if I fully understand that.
The example I am working on (ticket type) is named 'Important Dates'.
Where do I input the ticket type name to make sure this automation is looking at the right due date (under the right ticket type) please?
The first part of the above automation - Trigger.
should I select 'Basic' or 'Advance(CRON expression).
Would you be so kind and add a bit more screenshots to cover the above scenario going through it step by step please?
Thank you very much in advance.
Sure... My environment is a bit different than yours, but here are some screenshots of how you this would work:
