I would like to set a post function or trigger to the 'issue moved' event. The goal is that when issues are handed off between teams, that change will trigger a transition or status update so the issue will populate to the new project's triage board for product owner review.
Hi Jessica,
You should take a look at the automation plugin, with this you can do some transition based on events.
https://marketplace.atlassian.com/plugins/com.atlassian.plugin.automation.jira-automation-plugin
Thanks Sana, that plugin looks awesome. Unfortunately it doesn't meet my needs as it is unavailable for Cloud.
Register now
