Set workdays in BigGantt
Renee Linford September 18, 2020
Hi!  I am working with BigGantt (don't have BigPicture), and I need to make weekends available as workdays.  I've tried looking up how to do this under Jira Administration, but I cannot find the "Add-ons" option to change the workdays option in BigGantt.  Does anyone know if this is possible and how to do it?  Thank you.
Ok, I managed to find it!  In the future, if someone has this question, here's what I did.  I went to the Administration, selected the upper left had corner options, and selected Jira Software, which took me to my Jira Software Projects.  From the menu ribbon at the top, I selected Apps then BigGantt.  Then on the right hand side, from a grey window with options, select Administration.  That takes you to the adminstration side for BigGantt.  Select the Holiday Plans tab, then select the Default Holiday Plans.  Here you can click "edit details" to deselect the Saturday and Sunday options and click "save changes."  That should change the Gantt Chart to have weekends available as workdays.  :)
Артур Голубев
October 3, 2023
You are breathtaking! Thx
Like mehdi zirack likes this
mehdi zirack
April 6, 2025
Great answer. Tnx dear
Stephen Addis
September 19, 2020
If you want to use big picture, requires board to be added to a team to do ... but strangly doesnt require anyone to be in the team.  So create yourself a team, like IHAVENOFRIENDS and add it to that, do what you need, then remove from the team.
FREE
Register now
