Hi @Paola Jafrancesco welcome to the community. If you base your swimlanes on Stories the sub-tasks will show. Another solution would be to include them in your filter query for the board. Swimlanes based on stories is easier :)
I think you could solve it using a sub-query!
I mean a JQL something like this:
parent = subquery("sprint in activeSprints()")
Basically you collect the sub-tasks whose parent is in an active sprint.
Subqueries are not available in the built-in JQL syntax, but there are multiple apps that provide it. I think ScriptRunner is one of them.
Hi Aron, thanks for the answer but my point is that I'd like to see them in the "Active Sprints" view
