Hey,
I am using Jira Cloud and am my users are reporting that the search in custom fields is now case-sensitive (from 31st May) and it wasn't before. I honestly don't have recollection of that but now when I test it, indeed it is case-sensitive.
I couldn't find any changelog that reflect a change relating to that, can you advise if this was changed or was it always case-sensitive. Thanks!
What is the type of that custom field? I believe some of them, like Label, have always been case-sensitive.
Hi @Bill Sheboy
The custom fields are Select List (single choice) types, I have tried it with Select List (multiple choice as well)
BR,
Asparuh
I found this suggestion for this same symptom logged yesterday, so others are seeing this also:
That's really weird. Wonder why it would be for some and not others. Also, it would seem to be more of a Bug than a Suggestion if that's the case.
If Atlassian has made an update for the Cloud Instance, they are probablt doing it in batches so eventually all should be affected, the other option is to be a bug as you mentioned @John Funk
I am not having this problem at all. Typing in a lowercase letter shows values that start with both uppercase and lowercase. This sounds like it might be a browser issue. I will switch browsers and see if it is still happening.
Thanks for the suggestion, I have tested with Edge and Incognito Chrome browser and I get the same results, I have looked in the System Settings for the Jira Instance but I couldn't find any, if you have any suggestions where to look ?
No there wouldn't be any system settings for that. It sounds like a bug to me that only affects certain instances. Really strange.
