×Hi!
I have an issue using the slack app integration (with Jira Product Discovery).
When I want to create an issue from a slack message, I can do so by using the action "Create Issue from", and then it sends an answer to the slack message saying that an issue has been created from this message.
But when I select the action "Add to issue", the behaviour is not the same, no answer is sent to the slack message with the link to the issue it was added to.
I'd like to use these actions to keep people who gave insights that an issue has been created or that their insights has been added to an existing issue. In both cases, I need this message to be sent automatically as an answer to their insight so that they can be updated about the linked issue.
Is there a way to configure this? Or is it a problem that can be fixed?
Thanks.
