Smart value of Epic Name / Epic Summary not working
David Choi
I'm trying to retrieve the epic name or epic summary from a task of an epic.
I tried both and they do not give the name of the epic back in the automation.
  • Epic Link's Summary: {{issue.epic.summary}}
  • Epic Link's Epic Name: {{issue.epic.epic name}}
KAGITHALA BABU ANVESH
January 13, 2021 edited
Hi
If this is from the child of an Epic, you need to utilize "issue.epic." - eg:
  • Epic Link's Summary: {{issue.epic.Summary}}
  • Epic Link's Epic Name: {{issue.epic.Epic name}}
  • Epic Link's Labels: {{issue.epic.Labels}}
Edited by Atlassian:
The smart values are case-sensitive, so we edit the values above and they should work as expected.
David Choi
thank you for your reply.
Yes I tried all the smart values you mentioned, but they all do not work.
David Choi
unfortunately this issue is still open and I cant get the summary of the epic itself.
Martin Öhlinger
June 10, 2021 edited
I encountered the same issue and found a solution for it.
For some reason the smart value for Epics seems to be case sensitive
This worked for me:
  • {{issue.epic.Summary}}
  • {{issue.epic.Epic Name}}
Like 6 people like this
Tomas Orlik
I used
  • {{triggerIssue.epic.summary}}
  • {{triggerIssue.epic.Epic Name}}
instead of {{issue.epic.summary}} {{issue.epic.Epic Name}}, because you may be working in a different environment.
Tamer Solieman June 27, 2021 edited
I used {{issue.epic.summary}}, and it works fine with me.
