Smart value to update a line in custom field.
Zubair Khan December 15, 2021
When I'm trying to use this {{issue.description.match("(Customer Account\:.{0,15})")}} smart value in Jira automation.
The field result is like this Customer Account: "Customer Account:  XYZ  "
Is it possible to update only the name XYZ in the Customer Account field?
Matthias Gaiser _K15t_
December 15, 2021 edited
Hi @Zubair Khan
I haven't tried this myself, but you could try to do use a smart value with the replace function like this:
{{issue.description.replace({{issue.description.match("(Customer Account\:.{0,15})")}}, "Customer Account: NEWVALUE")}}
Does that work for you?
Alternatively, you could also store the value of Customer Account into a custom field. That's the way I'd prefer (without knowing your exact use case) in order to use it for filtering in other views.
Matthias.
Zubair Khan December 16, 2021
Hi @Matthias Gaiser _K15t_
Thanks for the response.
My use case is, I need to copy a line from description field to a custom field "customer account"
When I use this  smart value it's not working.
I see. Then I made it more complex than it was intended. You could simply use this statement then:
{{issue.description.match("Customer Account\:(.{0,15})")}}
Note that I have moved the rounded brackets to the actual part which you want to extract.
Matthias.
Like Zubair Khan likes this
Zubair Khan December 20, 2021
Thanks a lot. It's working
Like Matthias Gaiser _K15t_ likes this
Barry Ozer March 22, 2022 edited
@Matthias Gaiser _K15t_ Is it possible to use the same match smart value to create user stories with the match being each user story summary? Here is screenshots to show what I am trying to accomplish and the error message I get. My goal is to be able to automate user story creation based on each Action Item recorded as a line item in an Epic's Description at the time of the Epic creation. Thanks for the assist in advance.
Screen Shot 2022-03-22 at 1.12.05 AM.png Screen Shot 2022-03-22 at 1.11.53 AM.png Screen Shot 2022-03-22 at 1.11.48 AM.png Screen Shot 2022-03-22 at 1.10.48 AM.png Screen Shot 2022-03-22 at 1.09.38 AM.png
@Barry Ozer - that should work.
I think you might have a problem with your regex and the colons, you could try this regex instead:
AI1: (.{5,35})
I often use a webpage like regex101.com in order to check the regular expressions I write.
PS: I'd generally recommend creating a new question - that way also other people will more likely jump in and help you. You could still tag me over there :)
Like 2 people like this
Thank you. I'll be sure to pose a question instead of an answer next time. That worked like a charm @Matthias Gaiser _K15t_ .
