Soft limits for Cloud to Cloud migration using Site Import
Sukruth M S
September 21, 2023
Can you please provide any soft limits for  Cloud to Cloud migration using Site Import
Raja Shekher
September 21, 2023
Hi @Sukruth M S - 200 Projects is the soft limit.
More information is available here: https://support.atlassian.com/migration/docs/soft-limits-for-cloud-to-cloud-migration-for-jira/
Raja
Ganesh Choubey D
Hey @Raja Shekher  consider a cloud instance with 300 projects with attachements size of 5 GB when the total backup size is more should we split them in parts ?
   If so, how to divide them in parts and does the site import take multiple backup files from what i know the site import wipes previous data associated can you help me with this query
Thanks and regards,
Ganesh
Raja Shekher
September 21, 2023
Hi @Sukruth M S - What I have done it in the past is -
1) Take the entire back up of Cloud
2) Create a new temp JIRA server
3) Restore the data on the temp JIRA server
4) Take the back up from the JIRA Server
5) Restore the back up taken from the JIRA server to restore it back on the Cloud.
I know this is a very Tedious process but there are some recommendation in this post
https://community.atlassian.com/t5/Jira-Software-questions/How-do-you-copy-1-project-from-one-Jira-cloud-instance-to/qaq-p/864151
Hope this helps!
Raja
FREE
