Sorting feature should be written in acceptance criteria or as a user story ?
Kanishka Prajapati
June 16, 2022
There are multiple columns which has sorting feature so I should write in acceptance criteria or I should prepare user story for it ?
Kit Friend
June 16, 2022
Could you explain a little more what you're trying to achieve and/or include a screengrab?
  • You can sort based on pretty much all fields, which are visually represented as columns
  • Acceptance criteria are typically included in the description body of a ticket, or encoded as test cases in your test suite or via a tool like Zephyr Squad/Scale
  • ACs should nest under the relevant User Story (if you're choosing to use User Stories as a way to organise work)
FREE
