Sprint Automation trigger for Sub Tasks
JasonB3 August 17, 2020
This is probably real simple and I'm just missing the plot, but I can't seem to get the Jira Automation trigger: Sprint Start or Sprint Complete to execute against sub tasks.
Does anyone have a way?
My JQL keeps coming up with only issue level not sub tasks. Even though the sub tasks have a sprint assignment and status is not equal to Done
I've tried this JQL too, and no go. I just get an invalid JQL response. Not sure where the error is or how to test a JQL with smart values.
sprint = {{sprint.name}} AND status != "Done" AND issuetype in subTaskIssueTypes()
My Sprint Complete code is similar. Only difference is that it's trying to unassign subtasks.
This is on a Next Gen project.
Any suggestions?
JasonB3 September 17, 2020
I found a workaround!
  1. Add a new field to Issues that receive subtasks (for me; bugs, stories, and tasks). This field will be used to detect changes later. I called mine AutoAssign and made it an integer field type.
  2. Create a new rule. I called mine: [AUTO_ASSIGN] Assigns Sub-Tasks
    1. trigger = Field Value Changed, Field monitors changes to the AutoAssign for any edit of issue.
    2. build your logic to perform work on subtasks as needed. I made mine as:
      AutoAssign=1, then Assigns Sub-Tasks same as Parent
      AutoAssign=0, then Unassigns Sub-Tasks
    3. lastly on Rule Details, make sure you check the box Allow Rule Trigger
  3. Create another rule. This one I called: [SPRINT=COMPLETE] Un-assign Sub-Tasks
    1. trigger = sprint complete
    2. logic starts with JQL branch with logic like:
      project = "YourProjectNameHere" AND sprint = {{sprint.id}} AND status != "Done"
    3. and edits all issues AutoAssign to equal zero.
  4. Finally, create one more rule for Sprint Start. The logic is the same as the sprint complete, just toggling the AutoAssign to equal one instead.
To my surprise this actually worked. Seems ridiculous, but at least I'm not blocked or doing a bunch of manual assigning.
Ste Wright
August 17, 2020 edited
Hi @JasonB3
Making a minor modification in the JQL should make this work
This is how I achieved this rule:
  1. Trigger: Sprint Started in <<Board Here>>
  2. Branch: JQL - JQL: sprint = {{sprint.id}} and status != Done
  3. Condition: Issue Type (field) equals (condition) Subtask (Value)
  4. Action: Assign Issue - specify user = Copy from Parent
^ {{sprint.id}} is the unique identifier, as opposed to {{sprint.name}} which can be a variable.
Ste
JasonB3 August 30, 2020 edited
Hi @Ste Wright
Nope that didn't work. Automation logs show that the JQL only returned Issues and No Subtasks.
Interestingly, I was trying to troubleshoot this and came across something similar with JQL and not using smart tags. See Sprint Query to find Subtasks Not working
Could it be possible that the issue isn't with smart tags or automation, but the JOIN between status and sprint?
PS, sorry for the late reply. Had to wait for a sprint cycle to complete to test.
Ste Wright
September 6, 2020 edited
Hi @JasonB3
It should work - I have this built in a Next-Gen project in our environment; it's how I tested the above!
I just re-ran the rule and it works on our instance - albeit 1 of the 4 sub-tasks didn't get located by the rule. I've not been able to work out why.
Is it still not working for you? I would advise creating a new Next-Gen project to allow you to start/stop sprints repeatedly when trying to replicate the rule :)
Ste
nope. that didn't work either... but I found a solution
