I'm trying to create a new swimlane on our sprint board based on epic color. I have about 5 epics with the same color that I want to group together. I tried the filter "Epic Color" = ghx-label-6 but that isn't working.
Anyone else have success with this?
I ended up using
parentEpic in (DBG-5594, DBG-5593, DBG-7086, DBG-7085, DBG-5598, DBG-6692, DBG-5596, DBG-6879)
I'll have to keep the Epic list updated but at least this shows all the sub-tasks under the same swimlane as the main stories.
Hi @Kristi Johnson !
It looks to me, that it is impossible out-of-box,
maybe it is possible to use external apps like:
- JQL Search Extensions for Jira - the JQL extensions
- etc.
If you are ready to consider them, then need to research.
Register today
