Sprint insight filtering
Yaron Azar January 13, 2025
My Team is using centralized sprint for all teams.
The sprints are managed in one general board while each team has its own board with filter presenting only the related tickets of the team.
Problem - the Sprint insight feature.
This feature analysis is based on ALL tickets assigned to the active sprint and not per the team board I'm looking at.
Is this by design or there is a way to force the Insight feature to include the related board filter in its analysis.
Regards
Manoj Gangwar
Hi @Yaron Azar, I have tested and it seems it is by design.
Yaron Azar January 15, 2025
This is what I thought as well, just wanted to verify that I'm not missing something.
Yaron
Eduardo Anflor - MindPro
Hello. @Yaron Azar
The OOTB insights functionality in Jira boards does not allow to perform this filter. I believe you can get this type of feature using apps such as Mindpro Insights. This app allows you to create interactive dashboards for any team and also provides you a "Board" filter in the dashboards created, where you can manage this scenario.
Other than that, I do not see any feature like this being implemented in the short term in the existing Jira boards.
I hope that helps.
Eduardo
Register now
