Standard or default fields are very limited
CHILUMKURU
Standard or default fields are very limited in Next-Gen projects.
Is there any way to enable some more standard fields without creating a custom fields say components, original estimate, remaining estimate, etc.?
Also is there a standard way to copy complete Jira project ONLY complete Configuration (Issue types, workflows, boards, backlogs, components, sprints, releases, etc.) from one Next-Gen project to another Next-Gen project/classic software project? assume same project setup is required.
G subramanyam
Hi @CHILUMKURU welcome to the Atlassian Community forum.
The Jira software is loaded with standard fields and configurations for the minimum use and reporting. So, the custom field configurations are the add-ons that helps better manage Jira issue types, workflows and planning. Having said, I would request you to access these links that better gives insights about the same:
https://support.atlassian.com/jira-software-cloud/docs/customize-an-issues-fields-in-next-gen-projects/
https://support.atlassian.com/jira-software-cloud/docs/available-custom-fields-for-next-gen-projects/
https://support.atlassian.com/jira-software-cloud/docs/understand-insights-on-the-board-in-a-next-gen-project/
I haven't tried the project copying with configurations/ settings between Classic <--->,Next Gen. Hence, requesting you to check this link on migrate between next-gen and classic projects:
https://support.atlassian.com/jira-software-cloud/docs/migrate-between-next-gen-and-classic-projects/
If you feel my post addressed your query, feel free to click "accept answer".
